so from what i have read i did the hard bypass correctly on my x910bt, yet i get locked out above the 10mph mark.
i understand there is a software fix for this but i really don't want to mess with that, so here is where i am confused.
i moved the mute wire to its new location and grounded that along with PB wire, yet when i hit 10 MPH the unit tells me that is has detected the ground wire is not correct.
did i do the ground incorrectly? if so then why am i able to watch video without the parking break engaged? is it mandatory to do both the hard and soft bypass?
one last thing, i have a subaru and the stock HU had a black wire (im assuming it was a ground) that no longer is being used, should i attach the parking brake wire to that one?
