I liked the unit because it is instant and do not need to boot, in retrospect I am not sure what is instant about the unit.
Is it that unit shows bluetooth connected when I turned on the key, and only to tell me my phone is disconnected after 15 seconds later. How lame is that, application should know when you turn off the power it is disconnected., in addition it tells us message saying it is disconnected. User expects to see connected message after starting unit, not disconnected message.. It happend before I got out of my car.. Hello!
Unit takes 32+ seconds finally connect to Phone, is it this 32 seconds called instant? Even F-series with updates boots up in 40 seconds.
The Unit pretty much takes same time as cold boot to lock into satellites, I am surprized it does not scan for the satellites based on last known co-ordinates. It takes more time to lock into satellites than my factory unit in my prius, and same time or more than portable unit.
Ofcourse it is only audio system that is usable instantly, but any basic audio system starts instantly.
So, can someone tell me what is instant about this unit?
Also, one observation I made, when the units battery is dead, it is loosing the all phone sync information!! Can it save to built-in flash memory? Later when the battery becomes weak, we end up syncing phone every start!!?
Why is Navigation volume different from Audio volume? Is there a specific reason for that. I would expect Nav volume based on my audio volume which is adjusted based on surrounding noise(highway vs local), I should not have to go to menu,settings to keep changing this volumes everytime I get on a highways and comeback to local roads? What kind of integration is that?
