Avic-F700BT question..
By photousa · Sep 23, 2009in Problems/Troubleshooting💬 4 posts👁️ 700 views
Posted Sep 23, 2009 · 22:33 UTC#1
I'm considering buying a used F700BT to put in my Saab. The seller is
saying that the port that hold in the main power harness is loose,
causing the speakers to cut out when the harness is moved. I'm wondering
how many of you have run into this issue? Is it something that I will need
to send the unit in to Pioneer for repair, or is it something I'll be able to
repair myself? Is this even a real problem? Thanks
Posted Sep 24, 2009 · 14:54 UTC#2
sounds like the connector is either dammaged or the solder points are loose on the board, so the part will probably either need to be resoldered or replaced, if thats somthing your up to then you could save a trip to the service center
Posted Sep 24, 2009 · 15:12 UTC#3
Thank you, I don't think I feel too good about soldering tiny connections, so I'd probably send it in for service. I'm been looking through this forum and it looks like basic Pioneer service is in the $60 to $80 range for basic stuff, does this sound reasonable for a Pioneer service visit of this nature? Thanks
Posted Sep 24, 2009 · 18:25 UTC#4
im really not sure about repair cost, since i'm a pioneer dealer, anything i send in to get repaired is always covered under warranty
