Not to mention the factory harness does not have a +12 volt accessory wire, so you'll either have to run a tap from the ignition or fuse box. Though the best option would be to obtain a class II databus interface for your truck.
The Periperal interface recieved GMH24 turned out didnt have a bridge across power leads. Once they sent me the correct one (with the jumper) no mod to the GM side of the connector was needed. Thanks for the tips!
I also have a Hummer H3 '07 and am going to install my AVIC-Z1 this weekend (from my readings the wiring is same as your AVIC-D2), confused with the harnesses out there for our SUVs. What is the model number of the "Peripherial interface" you had sent that corrected the incorrect GMH24 and where did you obtain it, also what price should I expect to pay?
Was your installation relatively simple? I've done stereos, speakers, amps, eq's years ago so feel comfortable but the vehicles 15-20 yrs ago are far different than our H3's of today. Fortunately this forum will make the install a breeze.
...: Louie Alvarez :...
