F900BT to JBL Synthesis...
By ecpiii · Sep 24, 2009in Problems/Troubleshooting💬 4 posts👁️ 906 views
Posted Sep 24, 2009 · 13:36 UTC#1
Hey guys. I just bought a 2008 Toyota Sequoia with the JBL Synthesis system. My installer used a TYTO Metra harness to integrate into the factory amp. For some reason, the front speakers seem to be cutting out, or losing the high end signal. Sounds like the volume shifts. I have seen that PAC Audio recommends a 4V input, and the F900 only provides 2V. Is this the culprit? Should I switch to PAC Audio? RCA in line boosters created REALLY bad alternator noise, so boosting the signal is out.
Any ideas??
Posted Sep 24, 2009 · 14:47 UTC#2
a weaker signal should have nothing to do with the sound cutting out, it sounds more like a bad connection or a bad interface, i would start with checking the install to make sure that there isnt a problem there like a loose wire, if that checks out i would try a different module or a different brand module like the scosche TA07SR
Posted Sep 24, 2009 · 14:54 UTC#3
I think the Scosche is the next step, and then the PAC. Wiring all seems to be good, since I am just using the RCA outs from the F900. It even does it when I use the bluetooth on the F900. Go figure.
Posted Sep 28, 2010 · 20:22 UTC#4
I kinda have the same problem, i have the '08 tundra w/ JBL i have the Scosche. the problem i have is the front speakers and the sub are the only ones putting out sound.
