EU firmware update 3.0003 to 3.01 (tested on 900bt)
By Zelig · Sep 25, 2009in Hacks/Mods💬 15 posts👁️ 3,992 views
Posted Sep 25, 2009 · 07:36 UTC#1
For those of you who want to update the firmawere to 3.01 form Tomola's 3.0003 just download the latest official 910bt firmware form the Pioneer EU site and install it folowing the instructions given by Pioneer.
With this update you get:
APL: From 3.0003 to 3.001
Map: Form 02.000200 to 02.000400
WinCE: No change still 6.2.1.9
You also have to resintall the hacked EzRider.exe and the Global Licence if you are using hacked TA or NAteq maps.
Posted Sep 25, 2009 · 12:57 UTC#2
Hi, can you post some link? I downloaded this:
http://www.pioneer.eu/files/support/avi ... E_6219.zip
but in AP2/Igo/content/lang is only turkish and portuquese language and content folder isn't including map folder for maps update..
thanks
Posted Sep 25, 2009 · 14:59 UTC#3
thanks
3.01 is a system update, which means it contains only system files that changed since the last version. 3.0003 has the latest Pioneer provided maps. There is no map update inside 3.01.
Posted Sep 25, 2009 · 15:29 UTC#4
Yes, I thought it, but in first post is information about map update with this file from pioneer..
Posted Sep 25, 2009 · 15:30 UTC#5
I had the same issue with the turkish and portuguese. I copied over a new apl2 from Tomola and that worked im now running 3.01 and the 2009.06 maps with no problems (so far)
Posted Sep 25, 2009 · 17:30 UTC#6
this update over tomolas one or tomolas only apl2 over this ?
thanks
Posted Sep 25, 2009 · 17:46 UTC#7
Id pretty much bricked my avic so it was a long winded way i had to do mine. I updated the wince manually then used avic weo's apl2 & the rest from the update above. that left me with turkish and portuguese only so used tomolas apl2 and copied over the apl2 i had and now it seems to be fine.
Posted Sep 25, 2009 · 18:42 UTC#8
sorry guys but if someone copies his AVIC F900BT whole folder myflashdisk after the official update eu 302 works on all AVIC F900BT
Posted Sep 25, 2009 · 20:47 UTC#9
Installed this update over hacked 3.003 with no problems.Wonder what the changes are?
Posted Sep 25, 2009 · 20:49 UTC#10
Firmware UPdate History File
Model : AVIC-F910BT
AVIC-F9110BT
AVIC-F710BT
Ver.3.010100
- Stability improvement on iPod alphabetical search.
- Improvement on Track Log recording.
- General UI improvement.
According to Pioneer.......
Posted Sep 25, 2009 · 21:57 UTC#11
F900BT can install in a Spain?
work?
Expects no problems after installing.
It could put new maps?
greetings
Posted Sep 25, 2009 · 21:59 UTC#12
Works. Thank you!
Posted Sep 26, 2009 · 13:15 UTC#13
if someone could tell me how to put the new maps
thanks
Posted Sep 26, 2009 · 15:01 UTC#14
thanks
Search for the information in the topics. You will find all the information you need very easily.
Posted Sep 27, 2009 · 12:37 UTC#15
Thanks, works great on my 900bt EU. I only used system folders APL APL2 APL3 in testmode and whole APL2 with IGO8.3.
