http://www.pioneerelectronics.com/PUSA/ ... e+Download
AVIC-Z1 and Z2 Firmware Update Download
System Firmware Update Instructions for Model AVIC-Z1/AVIC-Z2
IMPORTANT:
Please download & print the AVIC-Z1&Z2 Firmware Update Instructions (Adobe Acrobat PDF, 210kb) for your reference when downloading and installing the firmware update. It is very important that you complete all steps correctly and in the order described below.
The data saved or recorded onto your navigation system by the customer cannot be guaranteed. Lost data that was saved or recorded by the customer is not guaranteed.
Note: If you have any difficulty carrying out these instructions, please contact Pioneer Customer Support Center.
Toll Free in USA 1-800-421-1404
Before updating
Please check your system version and confirm the correct update file for your system.
First select the “Settings” tab.
Then select the “Hardware” tab.
Select “Service Info Screen”.
Then you can see your map version number on the screen.
Please click HERE if your "Version" shows "01.0000".
You will go to the "Z1firmwareupdate.zip" download page. Please download the file to your computer.
Or, use update disc part number: GXY1016 and go to Step 4.
Please click HERE if your "Version" shows "02.0000".
You will go to the "Z2firmwareupdate.zip" download page. Please download the file to your computer.
Or, use update disc part number: GXY1017 and go to Step 4.
Downloading the Firmware Update
Step 1
Once you have downloaded the file to your computer, locate the file on your computer and double click the file to decompress it. If you do not have a decompression utility installed on your computer, you can download WinZip at http://www.winzip.com.
Step 2
Open the decompressed folder which named "Z2 firmware update" or "Z1 firmware update". Then you can find a "AVICZ1_HD1" folder and "Basefile.dat" file in it.
Step 3
Copy the "AVICZ1_HD1" folder and "Basefile.dat"on your CD-R.
*Note: Ensure these objects are located on the top layer of the CD-R.
Make sure that your CD-R follows these specifications as follows;
- You can only use a CD-R finalized with single-session format.
- You can only use a CD-R finalized with "Mode-1" format.
Installing the Firmware Update into your AVIC-Z1/Z2
Step 4
Please load this CD-R into your AVIC-Z1/Z2. The system will automatically start the update process in 1 minute.
WARNING! While your navigation system is being updated, do NOT turn off the power to the navigation system. Severe damage to your navigation system could result from your failure to obey this warning, including but not limited to the loss of all content/data that is stored on the Hard Disc Drive (such as song files ripped from CDs as well as address book entries and other user information).
If your system do not reboot and start the update process, then please check your system and CD-R as follows:
Check your system version again and confirm that the update file which you've downloaded is the correct version for your unit.
Check your CD-R and confirm that the CD-R burned with correct format.
Step 5
Please wait about a few (7 to 10) minutes to complete all updates in the system. The system will be automatically rebooted after completed update process.
Checking the CD-R.
Started updating.
Updating the firmware.
Completed updating and then automatically restarted.
Step 6
Please follow these steps below to confirm the update process succeeded.
Press the “MENU” key
Select the “Settings” tab
Select “Hardware”
Press & hold left upper corner of the “Hardware Version” screen for a few seconds
Confirm that your system correctly shows information as below:
AVIC-Z1:
PlatformVersion: 1.000700
HDD Application Version: 1.050000
AVIC-Z2:
PlatformVersion: 2.000500
HDD Application Version: 2.140000
Step 7
Please eject the CD-R from the system. The car navigation system is now ready for use.
If you have any questions, please contact Pioneer Customer Service toll free at 800-421-1404.
Pioneer service representatives are available Monday through Friday, 9:00 a.m. to 7:30 p.m. (Eastern Time).
Copyright© 2007 Pioneer Corporation
