bypass problem
By kevin199 · Sep 26, 2009in General💬 7 posts👁️ 1,366 views
Posted Sep 26, 2009 · 18:11 UTC#1
I changed the data.zip the barking brake speed from 16.0 to 128.0.
I saved it and copied it into the folder!
But it did not work!!
Does somebody had the same problem or know the answer?
Does it fix that i can do settings, navigation and watch dvd while driving??
Thx Kevin199
Posted Sep 28, 2009 · 09:55 UTC#2
Did you ground the e-brake wire?
Posted Sep 28, 2009 · 11:18 UTC#3
I think!!
The radio was in the car when i bought it!!! :)
What is the colour of the wire??
Posted Sep 28, 2009 · 15:56 UTC#4
light green, and long as hell
Posted Sep 28, 2009 · 18:33 UTC#5
At 128, you will still get a warning and lock-out if you hit 80 MPH. I'd set it higher, say 250 or 300.
Posted Sep 29, 2009 · 18:02 UTC#6
I made a photo
Is one of the two the wire???
Posted Sep 29, 2009 · 19:03 UTC#7
No, don't ground the wire at your car's parking brake. If you do, then you will get a brake waring all the time. You need to pull the AVIC out, disconnect or cut the light green wire coming from the black connector on the AVIC, and then ground that wire. (Ground the end of the wire that is still attached to the AVIC connector, not the end to goes somewhere into the dash of your car.)
