f90bt bluetooth pairing
By gouda272 · Sep 26, 2009in Problems/Troubleshooting💬 6 posts👁️ 3,293 views
Posted Sep 26, 2009 · 19:50 UTC#1
I recently upgrated to the latest 3.x f90bt firmware. my iphone 3g with 3.01 was working just fine. however, i was having another issue which i posted to this forum about a VR catalog issue. While troubleshooting that issue i removed the pairing to my iphone.
My Iphone will no longer pair. i can get to the point where it asks for the 4 digit code and i enter 0000 but it says pairing failed.
any ideas ?
Posted Sep 26, 2009 · 19:59 UTC#2
I would try holding the reset button for 5 seconds while the unit is on. That will restore factory default settings. If that fails, call Pioneer and ask... though they will tell you to do exactly what I just told you, and you'll wait forever on the phone to find that out.
Posted Sep 27, 2009 · 15:24 UTC#3
Thanks, i gave that a shot and it didn't work. it just says "Could not pair 'Pioneer Navi'"
I even tried to change the name of the unit to pioneer instead of pioneer navi, and it still shows up as pioneer navi when trying to pair the phone. I had to stop working on it but i did not reboot the radio after i changed the name, nexts i get in the car i'll try it again to see if it is recognizing the name change.
Any other ideas ? The code would always be 0000 right ? it can't be anything else or does it even matter what it is?
Posted Sep 27, 2009 · 15:46 UTC#4
AFAIK the code should be 1111, also try pairing from the phone and not from the unit
Posted Sep 27, 2009 · 16:09 UTC#5
Thanks IDT..that was it. could have sworn the code was 0000 but 1111 did the trick.
P.S. Your mod makes this navi soooo much better.
Posted Sep 27, 2009 · 18:12 UTC#6
no prob
