sirius antenna for xm??
By ibeb · Sep 28, 2009in XM/Sirius/HD Radio and Traffic Receivers💬 3 posts👁️ 2,082 views
Posted Sep 28, 2009 · 02:20 UTC#1
I just picked up an 06 F150 King Ranch that had the factory sirius radio. I have the Avic-D3 and the XM unit and installed it the other day from my 04 F150. Previously I had been using the antenna that came with the pioneer xm unit and did not have any problems, and cancelled my xm service a while back because I never listen to the radio and primarily use my iPod for music. When putting the system in my new truck I decided to install all the components in case I change my mind down the road and was able to plug the stock sirius antenna into the pioneer xm unit (just removed the plastic plug cover). I can recieve channels 0,1 and 247 and am wondering if the antenna will work for the complete xm line up if I sign back up?? I mounted my sat antenna on the metal braces of the dash and get 7-8 of 8 antennas on the signal meter and would love to not have to run/mount the xm antenna - on the dash doesn't work where I am at, needs to be on the roof. Thanks for any info - Erik
Posted Sep 28, 2009 · 23:59 UTC#2
Yes, you can use your factory antenna and still get the full line up. I am using my Dodge Ram stock Sirius antenna for XM and Nav Traffic. No problems.
Posted Sep 29, 2009 · 01:50 UTC#3
Thanks for the response. Was doing some searching and found a couple other posts that said that I should, but nothing recent and some said that they were only able to get a smaller range of channels. Thanks agian - Erik
