Just an observation - Voice Commands on the x910bt are crap
By Geoff · Sep 28, 2009in General💬 22 posts👁️ 3,721 views
Posted Sep 28, 2009 · 07:18 UTC#1
I had an f700bt previously, and voice commands were understood 80-90% of the time. With the x910bt, voice commands are understood, MAYBE 5% of the time...it's overall just more frustrating. Is this a hardware problem? The F700's feature was handy...the x910bt's is just about useless. I've seen this mentioned before, but I figured I'd chime in. :)
Posted Sep 28, 2009 · 15:48 UTC#2
So far I agree with you. It's a bummer, but I'm following the directions very carefully and have the microphone positioned properly and find it virtually never understands what I'm saying. So far, essentially useless for me as well. I try to remember that "operator error" is not an uncommon cause of my technology frustrations and will continue seeking out feedback in the hopes that the hardware/software is fine, but the user is what needs the adjustment :(
Posted Sep 29, 2009 · 02:44 UTC#3
Its worthless for me to....ive tried it multiple times and it was right maybe 1 out of 20. The worse thing is when you want it to "change source" and it decides to calls someone you havent talked to in months instead. You can never hang up quite quick enough to stop it before it rings once or twice...
Hopefully the voice reconition is a software issue and will be fixed in future releases. As of right now, its usless so I have completely given up on it. The only thing I use the microphone for is handfree speaking after I initiate the call on my phone.
Posted Sep 29, 2009 · 03:08 UTC#4
Is anyone having luck with using voice commands and, if so, any tips for those of us that are having problems? Mic location? Pronunciation or enunciation? Poem, haiku, anything?!?!?
Posted Sep 29, 2009 · 15:41 UTC#5
There is a slight difference between the F-series (2.0) and the X-series (3.0) VR software and it is important to know this difference otherwise you will not have very good success with VR after switching to 3.0
I had an F700 in my car for about 8 months and my VR worked perfectly on everything but when i switched to an X910 with 3.0 i was having a terrible time getting the VR to work properly. I was doing everything i did with my F700 so i could not figure out what the problem could be but i finally figured it out....
On the F700 i would simply press the VR button, wait for the chime, and then give the VR command and it worked great.
but if you have 3.0 it is important that you WAIT AN EXTRA SECOND after you hear the chime before you start talking. you have to wait until the purple dashes around the little face icon begin to light up. this one second pause was not necessary with 2.0 but if you do not pause with 3.0 the unit will not hear every word you say and will almost certainly misunderstand you.
give this a try and hopefully it will help most of you with your problems.
Posted Oct 02, 2009 · 18:56 UTC#6
Nope, it just takes one more second for it to incorrectly interpret what I've said now.
Posted Oct 02, 2009 · 21:15 UTC#7
if you are having problems with making phone calls with your voice you need to make sure your phonebook does not have any contacts with symbols in them including dashes (-), slashes (/), apostrophes ('), ampersands (&)...etc...
i have heard from a lot of people with iPhones having problems with the voice recognition. make sure your phonebook is sorted by First Name Last Name, make sure each contact has its own entry. for example, do not have a folder called "Smith Family" and then have "Bob Smith" and "Susie Smith" and "John Smith" listed under that. each person needs to have their own entry.
if you are having problems controling your iPod with voice commands make sure the AVIC does a VR Catalogue Update on your iPod before trying to use the voice commands. every time you add or remove a song from your ipod this needs to be done otherwise it will play the wrong song. it is essentially like a table of contents, if you add a page between 38 and 39 you need to adjust the table of contents and page 39 now becomes page 40.
from my experience with dozens and dozens of customers it almost always ends up being user error or a phonebook problem when the voice commands do not work. also, if you have a thick accent of some kind you will probably have issues.
Posted Oct 05, 2009 · 05:53 UTC#8
Perhaps not relevant, but I use the mic for GM onstar and it works perfectly.
Posted Oct 05, 2009 · 16:15 UTC#9
Same mic that I used with an F700BT, and EVERY command is not properly understood. Same mic worked as flawlessly as can be expected with the F700BT. My accent didn't change, and I'm not trying to call anyone, because I haven't synced my phone up yet.
Posted Oct 05, 2009 · 18:39 UTC#10
What are you trying to use VR for? iPod? only thing left I can think of is to make sure you VR Catalogue your iPod.
there is always the possibility that there is a problem with the unit but USUALLY that isnt the case. however, its not out of the question.
Posted Oct 07, 2009 · 14:25 UTC#11
also make sure that you have remove apostophes from peoples' names. if you have John O'Neil make sure you change it to John ONeil
Posted Oct 11, 2009 · 19:43 UTC#12
I'm just trying to use it for iPod voice control. That's all. It fails in every way conceivable vs my old F700BT. Friends with the same unit have noted identical problems with the x910bt's voice recognition being crap.
Posted Oct 12, 2009 · 13:42 UTC#13
Well i can tell you that the VR in the F series and the VR in the X series are basically identical. the only difference as far as I know is that you have to wait an extra second or so on the X series after you here the chime before you start talking.
i had an F series and then switched to an X. for the first few weeks I had my X I hated the VR because it never understood what I said. thankfully I found out that it was just that i started talking too early and it was only hearing part of what I said. after I discovered this it has been working perfectly for me for the last 4 months.
dont be offended but I still think its user error. and its not necessarily your fault because it is my opinion that Pioneer messed up and made it difficult to use. i know many people are having the same issues but with my personal experience with my car and my experience with dozens of other cars i believe your issue lies in how/when you are giving the voice command.
Posted Oct 19, 2009 · 22:12 UTC#14
I have seen the user "Newman" suggest that our units would perfectly fine if we waited some nominal amount of time for the Avic to recognize voice commands. I'm here to say that NO amount of waiting or any degree of the purple circle countdown allows the Avic (I have a x910BT) to recognize even simple voice commands. I have a mid-western accent which I have tried modifying, speeding up, slowing down, pausing before I start speaking - I still get a 10%-25% success rate for simple commands and a 0% with more complicated commands (usually by changing my ipod to some random artist). If you have the same experience, you are not alone. It appears that the vast majority of these units have VR issues. I constantly ask people how my voice sounds over the Mic to see if there is any distortion that would cause the VR problems - most people say that my voice is clear and understandable. So I doubt this has anything to do with installation or hardware. VR remains the single glaring weakness in Avic-X units and I have seen no response from Pioneer on this issue. :evil:
Posted Oct 19, 2009 · 23:15 UTC#15
Where did you find the mic wire? Did you need to re-wire the end to mate up with the AVIC head unit? I would like to try that on my Silverado, so any help would be appreciated.
Posted Oct 20, 2009 · 14:28 UTC#16
You could be right but I am just speaking from experience. We have installed more than 25 X910s in the last couple months and we installed countless F series last year. Of all of the complains we had about the VR, not a single one ended up being the VR software. every single one was user error or phonebook entry problems.
most issues I saw were users with iPhones and it always ended up being the phonebook settings in the iPhone.
as for the ipod, i do not have a reason why the ipod VR is not working for you. the only problems i have seen with ipod VR have ended up being user error or VR Cataloging errors.
there is always the possibility there is a problem with the VR software but if you are getting a 25% success rate that seems unlikely. i would expect it to be a 0% success rate if there were problems.
sorry I couldnt help.
Posted Oct 20, 2009 · 14:47 UTC#17
here is something else i figured out about the bluetooth...
when you update the phonebook in your PHONE and want to tranfer it to the unit there are a series of steps you need to follow to make it work correctly.
when you press the TRANSFER CONTACTS icon it will give you a message that says something like "ALL CURRENT ENTRIES WILL BE OVERWRITTEN. DO YOU WANT TO CONTINUE?" unfortunately even if you hit YES this will not overwrite the CONTACTS on the unit. it should, but it doesnt. so if you have taken all of the symbols and periods and apostropes out of your phone and then "OVERWRITE" the old contacts in the navi with the new ones, this will not actually change anything.
this is what you need to do...
with your phone connected:
1.) go into phone setup and scroll down to CLEAR MEMORY
2.) choose CLEAR all and confirm that you want to clear the memory from the navi
3.) disconnect your phone
4.) delete the phone from the navi's bluetooth memory
5.) delete the navi from the phone's bluetooth memory
6.) turn off the navi
7.) re-pair your phone to the navi bluetooth
8.) re-transfer your contacts
it is stupid that you have to do it this way but this is the only way I have found that it works.
so for all you out there who tried what i suggested about taking all ampersands, commas, periods, dashes..etc... out of your phonebook, you need to follow these steps to see if that truely solves your problem.
i know this wont help with any of the iPod VR issues but I wanted to make this known in case it does help some of you with your bluetooth VR problems.
Posted Oct 20, 2009 · 15:02 UTC#18
one more suggestion...
someone in the Z110BT troubleshootinf forum suggested resetting and re-syncing the ipod and that seemed to help the user with iPod VR problems. give it a shot.
Posted Oct 24, 2009 · 15:37 UTC#19
I will attest that I was very frustrated with the voice dialing. I have read through several posts and while the consensus seemed to be that special characters were the culprit, I was sure I didn't have any. That is until I received a phone call the other day from a friend of mine, we'll call Mr. Cedeño. Then it struck me, the tilde. Yesterday I changed the ñ to just an n and resynced my phone and contacts. After that, I was able to call about 6 different people with 100% accuracy. I am very pleased now.
Posted Oct 24, 2009 · 15:38 UTC#20
I did have some people in there with periods such as Dr. So and So, but so far that doesn't seem to matter.
Posted Oct 27, 2009 · 00:30 UTC#21
Anyone know where Multi-fucntion key is on x910bt. Not able to enable voice command.
Posted Oct 27, 2009 · 15:27 UTC#22
the multi-function key is the black knob on the left of your unit. rotate it to control volume. press left and right to change song/radio station, press up and down on map screen to zoom in and out, and press straight in to active voice commands.
the voice commands will not activate unless you are on the map screen or a source screen (radio, cd, ipod...etc..). if you are on a menu screen or setting screen pressing in on the knob will not do anything.
also, the voice command software is pretty much the last thing to load when the unit turns on so it does take a couple minutes before you are able to use the voice commands when you first get into the car. if you press the knob before the voice software loads it will not do anything.
