This site is awesome, thanks for all of your information!
F900bt running version 3.0
I upgraded to 2.6, added the brake speed patch, but had to ground the brake wire to get it to work, and all was fine.
Upgraded to version 3.0 and re-applied the speed patch, but now when I get to 16MPH, it locks me out of playback, etc. I know that patch is working since there were other mods for GPS buttons, which work fine. I also looked at the .ini file and it is set to 256. I also now get a message detected improper brake wire connection, which I didn't have before on startup.
Also is there a way to manually add contacts rather than all contacts on my phone. When I did install all of the contacts, when I receives calls from those contacts, it displays caller as unknown, rather than there name?
Please Help if you have any ideas! Jdude
