Problem with 3.0 to 3.01
By iamjeff · Sep 29, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,129 views
Posted Sep 29, 2009 · 01:33 UTC#1
I found all the info here great. I just have one question.
I did the 3.0 upgrade then the 3.01 and it all went smooth, but is anybody else missing functions on their f90 after the update? The 3 settings in av system settings ( Mute input/guide, Rear sp, and wide mode ) are not available.
Jeff
Posted Sep 29, 2009 · 18:20 UTC#2
Switch to radio and/or unplug your iPod - it should do the trick!
Posted Sep 30, 2009 · 00:38 UTC#3
Thanks for your reply. I tried that and it didnt fix it. Does anybody else have this problem?
Posted Sep 30, 2009 · 00:48 UTC#4
switch to off that will make the two available and wide only is available when viewing video
Posted Sep 30, 2009 · 01:29 UTC#5
I tried that also.
Jeff
Posted Sep 30, 2009 · 02:58 UTC#6
I think I figured it out. I went back to 3.0 and they were available,so I set them, then I set the eq to a custom setting and they dissapeared again.
