Setting Default City in 3.0
By XBinRochester · Sep 29, 2009in General💬 17 posts👁️ 3,433 views
Posted Sep 29, 2009 · 11:31 UTC#1
After upgrading to 3.0, my default city for looking up addresses became Buffalo, NY. That's an hours drive away from my home town. My home address is entered as a Rochester, NY address. Does anyone know how to change to default city? It's a real pain to have too change it to Rochester every time I have to look up a local location, which is the majority of the time. My car has never been to Buffalo, so I have no idea how that became the default.
Posted Oct 01, 2009 · 04:08 UTC#2
Same here. I just did the update and my default city is Los Angeles even though I'm in NY. How do I fix this?
Posted Oct 01, 2009 · 13:39 UTC#3
reset user settings
Posted Oct 01, 2009 · 14:33 UTC#4
I've gone through several mods and resets and it's always the same. I use the IDT mods and I delete all of my user data each time I 'upgrade' to his latest mod. There is mention in your sys txt about default location. I just don't know the coordinates of my current location to change it. My default city is Columbus Ohio, about 110 miles away from my city.
Posted Oct 03, 2009 · 04:53 UTC#5
Never mind. After running the nav. it automatically fixed the default city to the correct one. Hope the same goes for others.
Posted Oct 03, 2009 · 10:20 UTC#6
I have run the Nav many times since upgrading and it hasn't changed yet. Still hoping someone has an answer.
Posted Oct 03, 2009 · 13:42 UTC#7
Sounds to me like you might have a bad connection to your gps antenna.
Posted Oct 03, 2009 · 16:01 UTC#8
It's not a problem with the antenna, the GPS works great! The only problem I am having (knock on wood) with the 3.0 upgrade is the default city is locked on Buffalo. I can change it to another city and it will find and route me to the selected locations, but the next time I go to input another location, it comes up with Buffalo as the default.
Posted Oct 03, 2009 · 16:14 UTC#9
change the values of these code in your sys.txt and that should fix it
default_latitude="34.05116"
default_longitude="-118.24258"
Posted Nov 11, 2009 · 21:28 UTC#10
I finally got to change my default settings and it did not change the Columbus default city. Anybody find a definite answer yet?
Posted Nov 11, 2009 · 21:41 UTC#11
I have the same issue, it gives me Toronto instead of Ottawa as the default. My home address in an Ottawa address and I have used the Nav 100's of times in the city (I get lost otherwise) and still, default Toronto.
Any help would be greatly appreciated.
HR
Posted Nov 11, 2009 · 23:23 UTC#12
HR
Move to Toronto........ (sorry, I couldn't help it) :D
Posted Nov 12, 2009 · 00:47 UTC#13
I called Pioneer and they said that is the way the new system works. First she told me that "it defaults to the capital of the state", and I asked her what year our capital of NY changed from Albany to Buffalo? LOL What I do is just to the right of the default city is: HISTORY, just a touch there and you can hit your home town. Not a fix, but a quick work around.
Posted Nov 12, 2009 · 10:46 UTC#14
I did try changing the sys.txt and it didn't help.
Posted Nov 13, 2009 · 00:20 UTC#15
Haha, I think my mom would be happy if I moved back there but my wife might kill me! :lol:
HR
HR
Posted Dec 11, 2009 · 02:46 UTC#16
I'm having the same problem. It appears that the default city that shows when entering an address is the nearest major city to the one you're in.
So, when I'm in Dallas, it shows Fort Worth. When I'm in Austin, it shows Houston.
Has anyone been able to fix this?
Posted Dec 15, 2009 · 04:58 UTC#17
Well, this may make me look like a jerk, but I figured I'd share:
Thank you for contacting Pioneer Electronics, Inc.
I understand your request and the way it should work.
The engineers made the changes to the design.
We provide feedback to the engineers and request changes.
At this time, there are no updates planned for the unit.
Thank You,
Rocky
Customer Service Representative
Date: 12/11/09
To: [email protected]
Subject: Re: Feature and Specification
"Normal" is not acceptable - it worked properly prior to the v3 upgrade
which I paid $60 for, just a couple of months after spending $800 on the
device. I'd rather hear that this is a known issue and will be corrected
in a future release.
Is there an expected patch or fix coming?
[email protected] wrote:
Thank you for contacting Pioneer Electronics, Inc. I have reported your issue to our engineers for investigation. Unfortunately there is not a way to correct the address search. This is normal for our CNSD-100FM upgrade and the AVIC-X series. Thank You, Rocky Customer Service Representative
Date: 12/10/09
Subject: Feature and Specification
Inquiry Type:Feature and Specification lst
Inquiry:I have an F90BT and purchased the v3 update. Since installing, the default city when entering a GPS into the navigation system is the largest city next to me. For example, when I am in Dallas, it shows Fort Worth as the default city. When I travel to Austin, TX, it shows Houston, TX as the default city. How can I fix this?
