09 Tacoma Dash lights
By rsoduglas · Sep 29, 2009in Problems/Troubleshooting💬 7 posts👁️ 3,837 views
Posted Sep 29, 2009 · 23:22 UTC#1
After reputable installer was done, the main dash lights don't work. The AC controls illuminate and adjust via the dimmer switch. After hours of frustration saying it was wired correctly, it went back to the Toyota dealer who says all their pieces are fine and they think it should work. When they disconnect the Pioneer, the dash lights are back on. Any ideas?
Posted Sep 30, 2009 · 07:00 UTC#2
But does the unit change to night mode when you turn on the lights?
Only thing I can think off is, if the installer screwed up the connections in the wiring harness adapter. If he connected illumination wire somehow to ground connection, then you may see the those symptoms.
Posted Sep 30, 2009 · 20:05 UTC#3
No, there is no change on the Nav screen display between day and night mode.
Posted Sep 30, 2009 · 21:31 UTC#4
Then it is potentially Harness screwup by installer. He must have connected the illumination wire from your truck to ground or some other terminal on Radio side.
Posted Oct 01, 2009 · 12:16 UTC#5
I concur -- the installer probably botched connecting the illumination wire.
I have an '07 Yaris, which has same wiring harness as your truck (and all Toyota models since '87). I did the install myself. The AVIC has an orange wire with a white stripe (Orange/White) that is for Illumination. The harness connector I used (Metra 70-1761) has both an Orange wire (Illumination) and an Orange/White wire (Dimmer). For a proper install, you have to connect Orange/White from the AVIC to Orange from the harness, and leave Orange/White from the harness unconnected. If the installer didn't read the packaging and just blindly connected like colors, you would probably end up with a dimmer or illumination problem. If I had to bet, I would say this is what happened to you. Is there any way you can verify?
AVIC-U310BT Installation Manual
http://www.pioneerelectronics.com/Stati ... al0526.pdf
Metra 70-1761 Product Instructions
http://documents.victorytechnologies.co ... t/1058.pdf
P.S. There are two other aftermarket harness connectors I know of for Toyotas post-'87, the Best Kit BHA1761 and Scosche TA02B, but Metra is a very popular brand and it's likely that's what was used on your Tacoma.
Posted Oct 01, 2009 · 16:29 UTC#6
Thanks for the reply; I will take a copy of this info back to them for reference.
Posted Oct 01, 2009 · 20:13 UTC#7
No problem. I almost connected the wrong wires myself; I was only saved by being anal about instructions.
