Is there a guide anywhere to explain the various multiroute windows?Specifically,when you are on the page with the different routes highlighted in different colours,can you select a route directly from this page?Thanks.
Multiroute
are you referring to multiroute or multidraw, in multiroute when the route is clicked it will be set to that and in multidraw it is done by doing a long click on the box on the route type boxes on the left
Hi IDT.That was a FAST response!!I was actually referring to both but I hadn't noticed.So a long click on the multidraw will select the route?Is that in the box with a tick in it?Thanks.
if it has a box then it means that it is the current one, if it has a check what it does is it just shows you how the route would look like, so if yo longclick on a route type then it will set it as that then will return to the map
Understood,thanks again for your help.
no prob
