More Code Help Needed
By mr_cs · Sep 30, 2009in Hacks/Mods💬 5 posts👁️ 715 views
Posted Sep 30, 2009 · 20:03 UTC#1
I am trying to create a button that will change the vehicle type, with the following code
This works but the button image doesn't change as intended. I guess it is because the visiblemodel= bit is incorrect.
Can anybody help me put it rfght?
Colin
Posted Sep 30, 2009 · 20:52 UTC#2
It's generally not a good idea to give the same name to different objects.
Having said that, try something like
visiblemodel="ui.vSpeedcamSoundType=3"
It works in Stanislavovich's skin (for something else).
Posted Oct 01, 2009 · 07:16 UTC#3
Thanks for the quick reply and the advice on the name issue.
I note the reccomended code includes reference to cam sounds but I am trying to reference vehicle type i.e. car, lorry, emergency vehicle etc. On that basis is the code appropriate?
Again many thanks for all your help.
Colin
Posted Oct 01, 2009 · 16:34 UTC#4
Colin
It was just a sample code on how to include a comparison into a visiblemodel. You would use whatever condition you need for your buttons.
Posted Oct 01, 2009 · 16:47 UTC#5
Ok - thanks
Colin
