URGENT! Please help. In process of install!!
By clutchcake · Oct 01, 2009in Problems/Troubleshooting💬 2 posts👁️ 548 views
Posted Oct 01, 2009 · 03:26 UTC#1
I'm installing a Pioneer F90BT in a 2003 G35 Coupe with the factory bose amp. I'm using the metra 70-7551 harness and I seem to have everything hooked up but there is NO audio. None whatsoever. The unit turns on, I can switch audio sources, see the nav, but nothing will play out of the speakers. Please any idea what's going on? Anybody?
Posted Oct 01, 2009 · 18:20 UTC#2
you did connect the amp turn on wire (blue/white)correct?
its the wire that allows the AVIC to tell the Bose amps to turn on
