Hello everyone,
There is not whole lot of information about this unit, or any help anywhere on Internet or for that matter from Pioneer.
Hopefully we will get good info soon on this unit and lot of improvements, but it has to start somewhere, I observed few improvements with following.
1. Blue-tooth hanging:
This is pretty much common problem for U310BT.
The work around:
What I have observed is if you do not synchronize the phone book, it is not hanging frequently. So I just started using without synchronizing the phone book, and I only had one hang so far in 2 week(vs pretty much everyday).
2. Blue-tooth incorrect message, latency:
I think everyone might have observed that unit gives a message saying "Cell Phone disconnected" after you turned the ignition on. At about 32+ seconds it again says phone is connected. The issue with this was, blue-tooth program not recognizing that actual Blue-tooth module is shutdown when you turned off the key. The reason for this is, the unit itself is going into standby mode before it recognizes. So when programs comes back from standby, it thinks phone is still connected but can not find, and that's why we are seeing that message.
The work around:
There is a new Europe version firmware update meant for EU units. This is same version as mine, that is 1.0001. But it seems the blue-tooth software has been updated. I tried to update whole system, but it did not pick up complete platform, but did pickup Blue-tooth software update(Just follow the procedure outlined). My observation is this is not updating file permanently, rather loading into memory which is fine for this unit as it goes to standby usually. As long as we do not F.reset the unit, this works fine.
Here is the link for Firmware( You need to go down, select Firmware downloads and then select F310BT)
http://www.pioneer.eu/eur/content/suppo ... 700BT.html
I am not sure if this has any other improvements over old versions( vs what I have).
Improvements: Now, every time when I turn off my ignition, the U310BT does shutdown right-away as usual, but the LCD stays on for 5 seconds, identifies that Cell phone is disconnected with the message, then goes to standby. So next time when I start the car, it simply connects to phone. This reduced the phone connecting timing from 32+ secs to 18+ seconds and you loose the annoying/embarrassing " Cell phone disconnected" message after starting the car.
Note: Also, if your Radio is off( that means no CD, Radio etc is not on) blue-tooth starts faster.
3. Nav Freezing:
I have not observed Nav freezing after the update, but I am not sure if it has anything to do update. Even before update it only happened once for me.
Please add any tips:
4. Nav showing the in-correct location with full satellite signal:
This happened to be quite few time with my unit. The symptoms are you are moving fine, shows full satellite signal, but shows you are in wrong location (some time as far as 2-5 miles away from actual location) driving across with out roads.
The work around:
This can only be cured with un-docking and docking the unit back again. Just turn off the radio, and keep the unit in Non-Nav mode, eject the screen and put it back again. Rebooting the unit does not fix this.
Anyway, this is a start... ![]()
