New Map
By buddhabar · Oct 05, 2009in Hacks/Mods💬 15 posts👁️ 4,388 views
Posted Oct 05, 2009 · 21:34 UTC#1
There is a new map 2009 Q3 for navigon. Is it possible to use with avic? I guess that navigon use Navteq maps . I downloaded all eu maps but those are *.map* files. when I replaced to avic I didn`t get any map. any commands??
Posted Oct 06, 2009 · 01:19 UTC#2
Read!http://www.avic411.com/forum/viewtopic.php?f=34&t=27547
Posted Oct 06, 2009 · 09:28 UTC#3
??? this is not the answer what I`m looking for. The problem is files are different format. avic use .fbl those files are .map( like sweden.fbl vs sweden.map) .
Posted Oct 06, 2009 · 13:48 UTC#4
And this is your answer.
Posted Oct 06, 2009 · 14:45 UTC#5
Navteq maps WILL NOT WORK with the AVIC. They use TeleAtlas maps. The latest ones are posted here and they are the 2009.6 maps. You can't get any newer than that!
Posted Oct 06, 2009 · 14:58 UTC#6
Navteq maps work very well with 3.x AVIC software.
Posted Oct 06, 2009 · 15:03 UTC#7
Like Boris says Navteq maps work with Avic.I have tried both formats but feel the teleatlas are more detailed.Only my opinion!
Posted Oct 06, 2009 · 17:18 UTC#8
I allready use navteq with my avic but this is 2009 Q2 what I downloaded was Q3. That`s why I wonder if it is any possibility to change file format so we can use that version too.
Posted Oct 06, 2009 · 19:52 UTC#9
Not possible. You need to find maps in iGO format.
Posted Oct 06, 2009 · 20:06 UTC#10
My mistake, I read that the AVIC's only support Teleatlas maps. How do you make the switch? Do you just delete all the Teleatlas maps and then add the navteq ones?
Posted Oct 06, 2009 · 20:09 UTC#11
Delete which ever maps you wish to update,then copy the new maps over.You can even mix n match TA with Navteq.
Posted Feb 09, 2010 · 05:37 UTC#12
I didn't use the Navigon map files but I did use the Navigon DEM file. It's a tight squeeze at around 250mb!
Here is what it looks like driving through the Rockies:
Posted Feb 09, 2010 · 06:54 UTC#13
are you sure it's navigon or is it NAVTEQ?
Posted Feb 10, 2010 · 01:59 UTC#14
Good question... I downloaded the latest navigon maps to get the DEM file to hopefully get the 3d terrain view (i.e. mountains). So whether it's compiled by Navigon from NASA date, or compiled by Navteq, etc. I don't know.
This doesn't typically display like this on our units, does it? I have to admit - I didn't check before I updated it... :oops: But, in the driving that I've done before the update I hadn't noticed any actual terrain changes/topographic changes on the map. As mentioned though, the DEM file is huge... It's around 250mb for the US file. The Canada file is 106mb.
Posted Feb 10, 2010 · 15:50 UTC#15
I'm interested to test it on mine. Where did you get them?
