cant boot into test mode to fix what i messed up!
By jman930 · Oct 06, 2009in Problems/Troubleshooting💬 4 posts👁️ 702 views
Posted Oct 06, 2009 · 18:08 UTC#1
ok... so i updated to the new 2.006 and in doing so i looked around the forums to find a fix for the no tts problem i was having. saw that someone suggested that you boot into testmode and delete the tts files in the voice folder and then re add them. well being this is the first time i EVER went into test mode i accidentally deleted all the files in the voice folder and now my unit says starting up in progress please wait and never gets any farther. so i figured ok ill just boot back into test mode and put the files back in the folder ( which i finally found online after hours of searching ) but no such luck because now the unit will not boot back into testmode like it did before. so now im stuck and have no idea what to do... so if anyone has ANY suggestions as to fixing my problem please post!!!
Posted Oct 06, 2009 · 19:35 UTC#2
Are you using testmode2.3?This one will work even with 2.6.You can find it here
ftp://avic:[email protected]/
Posted Oct 06, 2009 · 20:02 UTC#3
I was but now I have decided to use the reboot fix and found out the 3.0 testmode file works best thanks for the post though!
Posted Oct 06, 2009 · 21:04 UTC#4
ok i have gone through and finished the reboot process walkthrogh in the help fourms and did everything to a T. When the unit reboots at the end it freezes at the splash screen... Sigh I have been working on this for 5 hours!! Help!!
