Hi Boris, thanks for the reply
The pocketgpsworld cams come in 5 different files. Mobile, Gatso, Redlight, Specs and one other, that at the moment (I am at work) I can't remember. Is that what you mean?
If I have to edit them, how do i do this?
I assume they are prepared as text files for iGO import. If they are, you need to make sure that camera type value (third number in every line) is set properly. I.e., mobile cameras are 5, static ones (Gatso?) are 1, red light are 3 (if red light only) or 2 (red light and speed) etc.
Ok Boris had a look at the files. Yes they are conveted to text.
My redlight files are like this for example( -2.10271,53.42484,3,30,1,242) It says at the top of the page (X,Y,Type,Speed,DirType,Direction ) I presume that the 3 before the 30 is the type even though it says type twice with different numbers??
To be honest it doesn't matter what camera I approach they all show they same warning screen, which is a little cam, with a lightning bolt and the distance and speed of the cam, is that correct too? Or should the nav system tell you what type of cam it is?
