Just Up graded from F900BT working just fine to a F90BT so I can put F900BT in my wifes car (Joan) After the install of the F90BT The map screen shows me to be 746 miles away in L.A. I am in Tucson ? Checked Navi settings it shows no GPS signal. Tried a reset three times. Then I Changed the antenna (Just in case) still no signal. I thing the unit is bad. I am going to exchange it. Unless somebody has a fix ? Put my old F900BT back in and it works just fine, so it's not a wire or installation problem. Thanks Jeff R.
Posted Oct 07, 2009 · 03:13 UTC#1
