XM direct style tuner
By topherchrisb · Oct 07, 2009in General💬 8 posts👁️ 1,494 views
Posted Oct 07, 2009 · 14:56 UTC#1
So I got my 910bt all wired for the most part and everything is working but my xm tuner. I'm using the tuner off my old stereo which isn't the pioneer one but the xm direct pioneer adapter hooked to an xm tuner best buy got me a long time ago. It worked great on my 8600, but the 910bt doesn't even see it. I've checked it's power lead, it's ground, it's fuse and no luck. Does this unit just not work with the higher end head units? That would suck, cause that pioneer xm tuner is a monster compared to this setup. I'll have to find some major room to install that guy.
I have an hd tuner in between the sat tuner and the head unit. I've tried hooking the xm tuner directly to the head unit but no luck with that neither. Tried a different IP-bus cable. I'm also worried about my subscription... I have a great deal running with my radio ID. If I switch to a different radio they'll probably reset my terms and jack up my price to the current plan prices. :(
Posted Oct 08, 2009 · 00:17 UTC#2
XM only charged me a small fee to switch radio id. All else remained the same.
If there is a reset button on your xm adapter press that along with the reset button on the 910 when every thing is hooked up and powered up.
I did not think the XM module to be all that big. The bus cable was long enough to put the module in the trunk.
Good luck
Posted Oct 08, 2009 · 05:08 UTC#3
I just installed my 910BT last night and when I called to switch my XM over this morning they told me it would be 15 dollars to switch it. I told them that was ridiculous and asked her how much it would be to cancel. I told her there was no way I was going to pay $15 dollars for her to type in a few numbers. She put me on hold for about two minutes and came back and said they would waive the fee.
Hope that helps.
Posted Oct 08, 2009 · 05:13 UTC#4
The pioneer tuner is much better build quality, and will display song and artist at the same time. The terk/Audiovox only shows one.
Posted Oct 08, 2009 · 12:03 UTC#5
Yeah I ended up going to get the 920xm Pioneer unit after another hour of trying to get it to work. I've had that Terk one for a long time now, so it was time to upgrade anyway. I'm glad to hear it shows artist and song info at the same time. I just switched the radio IDs last night and haven't been back out to see how it works just yet.
Over all the unit works better than I expected, and I'm super happy with it. The only two things I've noticed so far is the boot time and the VR stuff hasn't worked the greatest so far. I run an HTC touch with winmobile on it. So I'm used to that and I'm fresh off of the install and haven't messed with mic positions yet.
Snowboard season is just around the corner and I plan on getting the most out of this system while stuck in traffic on the highway coming down. :P
Posted Nov 06, 2010 · 04:26 UTC#6
I upgraded my buddy's D3 to an X920BT but kept his old GEX-P10XM or whatever...XM still works without calling to change radio ID's at all...either they don't check that often, or the radio ID for XM is built into the old Pioneer XM tuner and not the head unit...
Posted Nov 06, 2010 · 04:33 UTC#7
Good luck
No he's right...the GEX-P10 and P920 units from Pioneer are actually pretty large compared to other tuners (and even their own Sirius option).
By the way, I thought the "radio ID" for XM is actually associated with (and built into ) the tuner, not the head unit. If you're not changing tuners, then it should be the same ID, no?
Posted Nov 08, 2010 · 16:22 UTC#8
the radio ID is the number for the tuner itself, so that they cant control what tuners get service and which ones dont. so you only need to change the sat ID with XM if you change to a different tuner
