Alpha Layer bitmap AGAIN PLEASE
By gnasr74 · Oct 07, 2009in Hacks/Mods💬 7 posts👁️ 1,449 views
Posted Oct 07, 2009 · 21:59 UTC#1
no matter what i do i cant get an alpha layer to work with this bmp. i made it so i can have a onmap button for the cruise dial and trip computer when in route and i keep adding an alpha layer so it is round and it doesnt work still. i have done this for all my bitmaps and this one wont work, any suggestions
IDT_destindtrip_onmap.zip
Posted Oct 08, 2009 · 14:13 UTC#2
Not sure what all you tried but there was no alpha layer in the file you posted. So I added one, here you go...
Posted Oct 08, 2009 · 23:54 UTC#3
📎 IDT_destindtrip_onmap.zip
for some reason i couldnt get it to save with the layer, but thanks i will try it tomorrow
Posted Oct 09, 2009 · 18:01 UTC#4
i dont know what i am doing different but the alpha layers are not saving in photoshop. i thought you just have to outline the image, or outline the background and invert the selection. Then go to the channels and then create new channel. What am I forgetting? Please let me know. In the meantime can someone add an alpha layer to this image?
Thank you
746_32K_MN-110_32b.zip
Posted Oct 09, 2009 · 19:35 UTC#5
Here ya go, Alpha layer done..
As for PS and doing the Layer, I open up the file and use the magic wand to highlight the area and then on the lower right select the channels tab and then layer button. I do a save as... and make sure alpha layer is selected. I have tried just doing save but that does not seem to work all the time. Hope this helps.
746_32K_MN-110_32b_alpha.zip
Posted Oct 09, 2009 · 20:17 UTC#6
I dont understand the alpha layer stuff either. I've tried for weeks and nothing I do works. Trying to make a theme but been at a stand still for a month or so because I cant get some of the images to work properly. :oops::cry:
Posted Oct 10, 2009 · 13:09 UTC#7
thanks for all your help
