I'm new to this forum and it is packed with alot of information. However I'm just starting and stuck on the basics.
I just installed an AVICF700bt and I'd like to find out how to back up the existing software.
I've spent a few days exploring these forums including:
"Backup your existing software" in the AVIC Wiki
"FAQ Hacks & Modification READ BEFORE POSTING"
"Hacks-Mods F-Series"
"Did you skip backing up your F90BT"
and more.
There does not seem to be a step by step, updated description of the process. Here are some examples of question s I have:
1. It's recommended to download the TestMode files. There seem to be two versions - Testmode.zip and TestMode-V2.3.RAR. Which one should I use? I downloaded Testmode_2.3.rar and tried to unzip it and it appears that cecmd under /utils is corrupted. All others unzipped okay. Even if that was okay, there is no equivalent of MiTiACAP as in the other TestMode.zip. Which one should be used and what should be put on the SD Card.
2. When the SD card is put into the AVIC and the vehicle is turned on ... Sometimes it is suggested that it will go right into the CE environment, and some places say that you need to click an X in the upper right screen. What is the correct procedure.
3. I assume that the next step is when the AVIC is in the Windows CE environment. Is that correct? In that case it is suggested to copy "My Flash Disk". Is this a folder that is already on the AVIC? Does this include ALL the firmware related files that are AVIC specific?
4. Is the only medium that these files can be copied to, the SD Card (Storage Card) or what happens if I connect a USB Flash Drive (stick) to the USB connection? Will that show up also?
5. Note that I have the reverse question also. If I have to "restore" the AVIC software (firmware), then do ALL the files just go to the "My Flash Disk" folder in the Windows CE system?
6. In both of 4 and 5 above - do these files include the MAP files?
7. Does one really have to "Calibrate" the screen before using the test environment (Windows CE??) ?
Sorry for all these questions, but it's really hard to find one place with this info. If I've just missed it please point me to it. Otherwise, if you can answer these here that would be great. If I've missed a potential step or three, then I'd like to know that too.
Thanks alot for all the info. (And by the way - I did get a red knob which fits and looks great. So now that I'm done with the outside, I'm ready for the inside.)
