About To Buy AVIC-Z1
By johnyavic · Nov 20, 2006in Hacks/Mods💬 6 posts👁️ 1,810 views
Posted Nov 20, 2006 · 00:08 UTC#1
I have spent several hours reading this board, but just so I'm not confusing anything (I'm pretty much a beginner at this stuff).......if i purchase a Aug2006 or after unit, all I have to do is ground the 2 wires to disable the security features? I won't have the need to install any switches or anything? I ask because I'm most likely going to have a local car stereo installer (boomer mccloud) put it in, and they mentioned having to install a switch that would be located under the dash. This switch would disable the security features if i flickered it back and forth. Now maybe this was because the tech. was thinking about the pre Aug2006 units, but i figured you guys would know best.
So again, with the aug2006 and newer units the only thing that needs to be done is the grounding of 2 wires to disable all security features?
Thank you
Posted Nov 20, 2006 · 00:32 UTC#2
covered in many posts, but yes.
Posted Nov 20, 2006 · 00:55 UTC#3
Underline and bold many
Posted Nov 20, 2006 · 01:48 UTC#4
and enlarge text many
Posted Nov 20, 2006 · 02:51 UTC#5
Ok, I think he gets the idea... we have discussed this 1 or 2 times :)
Go here and there is info:
http://www.sminntech.com/z1flash.html
Posted Nov 20, 2006 · 10:26 UTC#6
thanks guys, just wanted to make sure i understood.
