when ever i put an address in it finds my current location and maps out my trip. but after a min or 2, it never moves, it just stays in the same spot. any suggestions on how to fix it...thanks
Posted Oct 08, 2009 · 21:10 UTC#1
Z1, Z2, or Z3?
Does your GPS work normal before you put in an address?
When the GPS does not move and stays in the same location, try pushing the 'map' button, and see if the GPS snaps to your current location.
z3
no it wont work in any mood, works for a min then stops moving
tried pushing map button but doesnt help
Try resetting the 3d calibration settings under Menu, Settings, hardware.
Also check your VSS is working and your GPS Satelite is getting a good signal.
