2009 Honda Accord EX VSS wire location Needed
By b1150c · Oct 09, 2009in Vehicle Specific Wiring💬 3 posts👁️ 2,072 views
Posted Oct 09, 2009 · 18:49 UTC#1
I have a 2009 Honda Accord Sedan, EX V6, with the factory 6 speaker, non duel heat controls, that I installed the AVIC-110BT into. I can not locate the VSS vehicle speed signal wire.. Can any one help?
Posted Oct 13, 2009 · 04:52 UTC#2
The newer navigation units are accurate and fast enough to not need to hook up the VSS wire. I have been installing professionally for over 10 years. Never had an issue with the newer nav units and needing a vss.
Posted Oct 13, 2009 · 20:16 UTC#3
That makes a lot of sense. Why in the world do you think they build the newer Nav units to accept the VSS? It DEFINATELY helps for tracking for the first bit of time after boot up until it locks back on the satellites. It also helps when driving through densely wooded roads, tunnels, double decker bridges, etc.
