I have a f700bt not currently installed in car.. (i bought it used..) I hooked it up to a 12v power source (red&yellow wire to positive - Black wire to negative) and it turned on fine but started rebooting after 10 or so seconds, so i did the latest update (2.006) and it worked.. but the only setting i can press are "AV Settings" and "AV sound" everything else is grayed out...and when I press "AV Source" all I can press is "AM" and "FM", when i press either fm or am it reboots... it also reboots when i press "eject". Is there something wrong with it? or is it because I don't have it installed in a car?
ANY help would be greatly appreciated!
