Any one installed Z110BT in a MKV GTI? Any installation guidance? Are you able to use the Phone Button on the steering wheel?
MKV GTI?
The PAC SWI-PS steering wheel adapter will retain your phone button feature as well as volume, track skip/seek, other features.
I just put a Z110 in my 2009 Jetta Sportwagen. You can use the PAC stuff to do the phone button or go Connects2 (as I did) which doesn't give you the phone button but it gives you all the other buttons as stock and makes the OK button a change source button which comes in handy more often. Also the Connects2 is about 1/2 the price and is about 1/4 of the size of the PAC parts you would need:
I just got the Z110 installed in my 2006 GTI MKV. Great fit. I used Connects2 module with Pioneer cable adapter... its one tiny unit instead of 3 PAC modules that you need and its a lot cheaper. I got it from a distributor in UK. Don't get PAC modules. they just don't work right in VW.
I can also confirm that the phone button does not work.
Don't get PAC modules. they just don't work right in VW.I can also confirm that the phone button does not work.
It does with the PAC module.
I just finished installing a Z110BT in my 2007 GTI MkV complete with steering wheel controls. The PAC SWI-PS and SWI-CAN were all I needed to get everything working, including the phone button and voice command on the AVIC.
One issue I ran into with the phone button is that you can either have it (a) answer (
hang up or © show phone screen. So I cannot answer AND hang up with the same button.
Yea you have to have a button on your steering wheel for each programable feature on the SWI-PS.
