F700BT grey icon problem
By grantrace · Oct 14, 2009in General💬 3 posts👁️ 2,277 views
Posted Oct 14, 2009 · 00:50 UTC#1
New member here, This is my 3rd AVIC unit i have owned and so far i have loved them all. I just recently bought a avic-F700BT installed her today with everything pretty much (subwoofer RCA, both front and back RCA speakers, wired mic, GPS antenna and USB cable).
The unit works, but there are a few things that don't work at all.
-I can access the settings menu however only two setting icons illuminate the other two are GREY (navi settings and system settings).
- Bluetooth phone, everything is grey even the setup option.
- Navi, i can only choose POI and "go home" everything else is in grey.
Does anyone know what this problem could be caused by? I have no way of checking what firmware the unit has because i can't even access the "system settings".
Posted Oct 14, 2009 · 01:15 UTC#2
you have to do the parking break bypass
Posted Oct 23, 2009 · 01:59 UTC#3
if you did the hardware bypass, check your splicing for the grounds. The same greyed out icons kept appearing for me even when I had everything set up correctly for the bypass. I undid all my taps for grounding out and turns out they didnt make a clean connection. I ended up splicing them together, old school style and everything worked perfectly.
