Use 3.0 on more than 1 unit?
By audioprecision · Oct 14, 2009in Hacks/Mods💬 4 posts👁️ 842 views
Posted Oct 14, 2009 · 22:06 UTC#1
I have purchased the 3.0 update from Pioneer. Is the any way to use it with more than 1 unit. I have a customer who has a fleet of vehicles that I installed (5) 700bt's and (2) 900bt's. It seems a little ridiculous to have to buy and update for each vehicle. I'm hoping it is as simple as modifying or removing a file on the 2nd SD card. Thanks, Tim
Posted Oct 15, 2009 · 03:30 UTC#2
I have also purchased the update and to my knowledge, the answer is 'no', it is only good for one system as the update has a registered device I.D (your unit only) with a password for only your unit. You can put the hacked version in which is identical, you just wont be able to update it with legit updates.
Posted Oct 15, 2009 · 12:06 UTC#3
Ok, so here is the weird thing about this situation. I originally bought the update to use on my personal avic-7010bt, and I have updated 3 of them with no issue. The first one, of coarse, I had to register to get the password. The other two didn't have any prompts for the device # they just started updateing. There has to be a way around this. These guys are hacking to change so many features, this should be simple. If need be, I can upload the update to let someone hack it.
Posted Oct 15, 2009 · 12:33 UTC#4
Then it would be the SAME as the one that is already posted in this forum. just download that, install it, and you are all set.
