hi everyone! need a lil help... can some one show me how i can run my stock sub with the avic d1? thanks!!! -wang-
Posted Nov 21, 2006 · 04:40 UTC#1
OK, you've got quite a job ahead of you. First off, there is a wire behind the radio that you must ground to keep the factory alarm from acting wacky, pin A4, don't remember the color. Audio to the sub amp is white(+) and orange/blue(-) for left, red(+) and blue/green(-) right audio to the equalizer unit, and remote is orange at the radio harness. If you are not using the eq, blue/green becomes purple, and orange/blue becomes yellow after the eq. Remote turn-on is blue at the amp, left sub input is red(+), green(-) and right is red(+),green(-) if you want to feed signal in right at the amp behind the right side seat back. Happy hunting.
