WHAT TO DO ABOUT A WARNING FROM UNIT WHILE MODDING
By ImAuDiS4 · Oct 16, 2009in Hacks/Mods💬 4 posts👁️ 752 views
Posted Oct 16, 2009 · 20:38 UTC#1
I MODDED MY FLASH DISK FILE ON MY COMPUTER USING dpdurst 3.0 mod v1.2 - updated 9/30/09 I DID EVERYTHING THAT HE SAID TO DO IN HIS POST. I THEN WENT TO MY CAR WITH THE SD CARD HAVING THE NEW FLASH DISK FOLDER ON IT. I BOOTED UP IN TESTMODE AND COPIED THE MODDED FLASH DISK FILE FROM MY STORAGE CARD. I THEN CLICKED PASTE TO REPLACE THE STOCK FLASH DISK WITH MY MODDED ONE AND A WARNING CAME UP SAYING THAT THERE ISNT ENOUGH SPACE AND IT WOULD TRANSFER AS MANY FULL FILES IT CAN, ASKED ME TO PROCEED YES OR NO. I CLICKED NO BC I WANT TO MAKE SURE THIS IS THE CORRECT WAY FOR ME TO MOD MY UNIT. PLEASE GET BACK TO ME AND LET ME KNOW IF THIS IS CORRECT OR IF I AM DOING SOMETHING WRONG. THE MODDED FLASH DISK FILE IS 1.82 IN SIZE AND THE STOCK FLASH DISK IS 1.72, WHAT DO I HAVE TO DO ??? AM I INSTALLING THIS CORRECT ???
THANKS
VINNY
[email protected]
Posted Oct 16, 2009 · 20:42 UTC#2
First you need to turn your caps lock off. Now, if you are getting that error, you will need to delete the contents of the flash disk in order to make enough space to accommodate the modded data. Just make sure you have a backup of the original data before you delete the data on the flash disk.
Posted Oct 16, 2009 · 20:44 UTC#3
Ok let me clarify a little more, What ever you are trying to replace on the flash disk, that is the files you need to delete. DO NOT delete your entire flash disk unless you are replacing it with an entire flash disk of content.
Posted Oct 16, 2009 · 22:02 UTC#4
Dude stop double posting everywhere also, one post is enough to get my attention or someone else I'm offline for the moment. I have answered your question in my thread where you first posted. Thanks
