Imaging Troubles
By jadiaz9 · Oct 20, 2009in Problems/Troubleshooting💬 4 posts👁️ 611 views
Posted Oct 20, 2009 · 02:25 UTC#1
Hey... First of all this site is awesome! Second of all for some reason I can't put the Image on any drive. I have a 40 Gig HD for some reason every time I try to put the Image on the hard drive the software reboots and then says that It can't find the path. I guess I am trying to do it in a complicated way through my Mac by using Parallels and running windows.
What would be amazing is if someone could make a (.IMG) Image file on a Mac of their Z3 Hard Drive, otherwise I am up a creek.
Does any one have any suggestions for me? Other than buying another HD with it on it already.
J
Posted Oct 20, 2009 · 02:44 UTC#2
Can you please explain in a little more detail the process you are following? I suspect you are missing a small detail somewhere.
Posted Oct 20, 2009 · 03:37 UTC#3
I am trying to mount the image using acronis. I don't have a PC so I am using a program called parallels which lets you run windows on a mac which means that I can't use a boot cd nor can I make the hard drive the master hard drive. The Hard Drive that I have isn't locked. All i need to do is put the image on the HD. It would be much easier if Some one could make an image for the Mac peoples. I would but my hard drive stopped working.
Posted Oct 20, 2009 · 03:44 UTC#4
Wow sorry i meant an .dmg image file.
