Object Identifier error question? Please Help!
By bryvale · Oct 21, 2009in Hacks/Mods💬 9 posts👁️ 1,123 views
Posted Oct 21, 2009 · 03:40 UTC#1
I have multicalc and multiroute set up on a quickstart menu. While Multiroute works fine I'm getting the error:
Unknown Object Identifier Identifier=[d_st_multiroute] script "[unnamed]" Command 0 when I try to get to multicalc
I got the Multirout/multicalc form Diaftia's Mod package and I've been combing through his files to find what I am missing but I can't find anthing. Can anyone point me in the wright direction?
Bryan
Posted Oct 21, 2009 · 04:03 UTC#2
Bryan
search for d_st_multiroute and see and you're missing something?
Posted Oct 21, 2009 · 04:14 UTC#3
Bryan
The only place I can find it is in the multicalc.ui file:
Where else should it be?
Posted Oct 21, 2009 · 04:15 UTC#4
Bryan
it could be anything, maybe you missed a > or mispelled something, look for anything suspicious
Posted Oct 21, 2009 · 04:29 UTC#5
Well, I copied all the files from Diaftia's mods. It seams like I'm missing something I just don't know where to look.
Posted Oct 22, 2009 · 03:50 UTC#6
I found the missing file and added what I thought was everything but now I am getting a new error
Parse Error[ expected]
Any suggestions out there?
Thanks,
Bryan
Posted Oct 22, 2009 · 11:31 UTC#7
Thanks,
Bryan
I have the same error, I just gave up on it. I never found it. It appears the multiroute stuff is based on something other than just the stock avic software. It appears to work fine with Andr2000 mod, IDT and Diaftia mod but the stock Avic software for some reason keeps kicking up with this error. Good luck. I though the layer issue might have been something in the navigatemap_800_400.ui file but no matter what I tried it never worked.
Posted Oct 23, 2009 · 00:21 UTC#8
Thanks,
Bryan
Did you follow "the how to add multiroute" post? I found a missing file in the place 800_480 file but I am still stuck. I can get the multiroute to show on the map but can't get the seperate multicalc page to work. Maybe we can compare notes to figure it out
Posted Oct 23, 2009 · 01:11 UTC#9
No I just figured I'd comment on what I found because I didn't follow. Of course I did, I already ran into the missing file and corrected all that and spent about 4 days working on it and just gave up. I have multiroute working in another mod so that works for me. Good Luck
