X910BT names will not appear for incoming calls
By lindsey09 · Oct 22, 2009in Problems/Troubleshooting💬 17 posts👁️ 4,335 views
Posted Oct 22, 2009 · 11:59 UTC#1
I have an IPhone 3GS and have paired and uploaded all my contacts to the system. When a call is reiceved the number and not the name of an uploaded contact appears. Why doesnt the name of my contact appear?
Posted Oct 22, 2009 · 20:27 UTC#2
I have the same unit and phone and I also have this problem. Very annoying since I dont know any ones numbers by heart.
Posted Nov 06, 2009 · 17:06 UTC#3
I dont have a solution for you but I am pretty sure this has something to do with the iPhone. it is very common for people to have bluetooth curiosities with iPhones. usually it all has to do with the iphone settings.
do you have problems when trying to make phone calls with voice commands? do your contacts appear in the contact menu?
Posted Nov 06, 2009 · 17:22 UTC#4
The following applies to ALL cell phones, not just the iPhone.
Make sure that your contacts are stored in EXACTLY the same format as your incoming caller ID.
ex. If you get an incoming call from someone who is not in your contact list on your iPhone it may appear as
+1-xxx-xxx-xxxx
If your contacts are saved as xxx-xxx-xxxx (without the +1 in front) then they AVIC may not associate the incoming caller ID with the phone number in your contact list because it is missing the +1.
This is just an example of how the format may be different, your mileage may vary. Just look for anything that may be different between the format of the received caller ID phone number and the way you have it stored on your iPhone. I had to do this with my phone to make the names appear on my HU instead of just the number.
Posted Nov 06, 2009 · 18:11 UTC#5
i don't get the names either with the blackberry.
Posted Nov 06, 2009 · 20:51 UTC#6
i do get names with my blackberry. what BB do you have?
Posted Nov 06, 2009 · 22:01 UTC#7
bold, i just get the numbers on the screen but no names?
Posted Nov 07, 2009 · 16:18 UTC#8
I just reformatted my contacts so the HU can match up with it and still just numbers. When a contact appears on the HU, example my HU has Mom Mobile because the iphone forces you to choose mobile,home, work etc... could that be the reason why the name doesnt appear when she calls.
Posted Nov 09, 2009 · 15:43 UTC#9
Have you tried clearing the memory from the navi and then re-transferring your phone book. i have noticed that if you simply try to overwrite your phonebook nothing acually happens. even though it will prompt you by saying "this will replace all existing contacts", it doesnt actually do that.
you will need to go into phone settings, then go down to clear memory and erase the stored memory in the navi.
try that to see if it helps.
Posted Nov 09, 2009 · 16:22 UTC#10
Having the numbers sorted by type will not cause the issue you are having. I have mine stored that way and it works perfectly. The HU actually recognizes the categories properly as well and allows you to specify the type when dialing.
Another thing to look for is duplicate entries. If the same phone # is stored 2x in the directory it can confuse the system and cause it to only show the number and not the name as it can't decide which one it wants to show (even if they are under the same name).
Posted Nov 09, 2009 · 19:35 UTC#11
the names and numbers on my HU match my phone and still when an incoming call is reveived it still just shows the number... I am getting so tired to have to look at my phone to see who is calling. I bought this unit because I read that this model adopted well with the Iphone... I am so dissapointed.
Posted Nov 10, 2009 · 15:02 UTC#12
Again, I would be willing to bet the issue is with the phone, not the navi. most people, even people with iPhones dont have this issue.
Posted Nov 10, 2009 · 15:20 UTC#13
So i have a blackberry bold. How do i fix this issues? My contacts are stored by some just by first name and some with first and last?
Posted Dec 02, 2009 · 13:59 UTC#14
i also have an iphone 3gs and i have noticed the same issue. i am going to do some testing tonight when i get home to see what format is required for the name to be linked to the number of an incoming call.
*edit: turns out the way the the iphone stores phones numbers is not compatible. the iphone stores as '(555) 555-5555' or '1 (555) 555-5555' and the avic needs '15555555555'. i guess i will just have to manually edit the entries using the phone book editor found here:
viewtopic.php?f=34&t=22601
Posted Dec 06, 2009 · 12:28 UTC#15
I agree the format on the 3gs for phone number has the (xxx)xxxxxxx rather than xxxxxxxxxx did the phone book editing work... if so how did you do it.. If not is there another way to edit the numbers... went to apple store yesterday and there isnt a way that they know to edit it on the phone.
Posted Dec 06, 2009 · 15:19 UTC#16
what i ended up doing was i synched all of my phone book entries to the head unit and then i copied the address book file from the head unit and used the phone book editing software found in this thread:
from there, i just removed the entries i probably would never need and edited them to the correct format which i now believe is '15555555555' (translated from '1 (555) 555-5555' from my iphone). it really isn't a problem with people's phones, it is just that the head unit really ought to format the numbers correctly upon importing. i still haven't verified it yet on the head unit that it reports correctly now with the name as i haven't driven my car in a few days and forgot about testing it.
Posted Apr 21, 2010 · 01:41 UTC#17
My Blackberry Tour also has this issue sometimes. Redo the contacts after a full boot of the phone.
