Proper wiring technique?
By 6605stang · Oct 23, 2009in General💬 4 posts👁️ 1,295 views
Posted Oct 23, 2009 · 21:18 UTC#1
So I've always installed all my own head units. And they've all always worked fine, however in reading threads here I've noticed a lot of people talking about soldering... ya, um, I never do that. Butt connectors and electrical tape has always been my method.
Does anyone here know of a thread or reference one could look at for a HOW-TO on proper wiring? I.E. grounding, harness pairing, etc.
This is probably a stupid question, but thats what I'm here for!
Cheers, JR
Posted Oct 23, 2009 · 21:22 UTC#2
Quick splices and butt splices FTW!!
Posted Oct 24, 2009 · 01:32 UTC#3
Ive installed all my own units for 15 years and never soldered and never had a problem. The first time I actually soldered was when I installed the PAC SWI-PS last March. It requires a resistor to be soldered to the negative wire. I have allways used splicing caps or connectors. Granted, soldering is best but in my opinion not a must to do a proper install. As long as your not going to be going in and out of your dash a lot and causeing stress on the connections I wouldn't worry about it. Go with what you know. If you deviate now from what has worked for you all this time you stand a greater chance of something going wrong. Just my 2 cents, hope it helps.
Posted Oct 24, 2009 · 02:13 UTC#4
Excellent point sir. That does go againsty personal motto though... If it ain't broke, F with it until it is!
