Device Emulator
By ovalball · Oct 26, 2009in Hacks/Mods💬 4 posts👁️ 960 views
Posted Oct 26, 2009 · 16:45 UTC#1
Can anyone tell me how to get back onto the map screen once you have been on the settings screen?
Posted Oct 26, 2009 · 21:43 UTC#2
depending on what mod your using, what i did on mine is i added a onlongclick='nextstate st_navigatemap' param on the "about" button as a shortcut
Posted Oct 26, 2009 · 21:55 UTC#3
Or you can go into the setting.ui file and look for the st_navisettings section. At the bottom there is a line of code with the following:
Change it to:
That will make the back button to back to the map.
Alex
Posted Oct 27, 2009 · 19:50 UTC#4
Thank you for your help fellas,all working fine now.
