Stupid wiring questions
By octundra16 · Oct 27, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,086 views
Posted Oct 27, 2009 · 04:00 UTC#1
1. What color is the mute wire?
2. Do you hook the VSS wire into the wire behind the speedo?
Thanks in advance!
Posted Oct 27, 2009 · 04:03 UTC#2
Oops, got the mute wire on the RCA connector. Still not sure on the VSS tho...
Posted Oct 27, 2009 · 04:43 UTC#3
The VSS wire is tapped into your VSS on your ECU.
Posted Oct 27, 2009 · 07:29 UTC#4
Thanks. I figured all the connections (I think) and everything works but no sound. Video, iPod, Navigation, the bypass - all seem to work fine just no DANG SOUND! I'm using a scoche bypass to use my stock JBL amp on my 2005 tundra. I'm wondering if it is the bypass or I just screwed up a wire somehow. Bad ground? Any ideas?
Posted Oct 27, 2009 · 17:28 UTC#5
Make sure that you connected the amp trigger wire and not the power antenna wire to the amp triggers. (both are blue, but one has a white stripe).
Posted Oct 28, 2009 · 04:41 UTC#6
Got it all in and love it! Thanks!
