For those with system startup message not going away...
By Steve973 · Oct 27, 2009in Hacks/Mods💬 4 posts👁️ 938 views
Posted Oct 27, 2009 · 17:35 UTC#1
I posted this in the 3.0 install guide, but since this is such a common problem, I wanted to post my experience on its own so nobody will miss it:
First of all, thank you very much to everyone for sharing their expertise and experiences. This made things pretty smooth. All in all, this update was a success with my unit (AVIC-F7010BT). I have experienced some of the problems that I see commonly reported here, so I will describe how things went for me...
My unit was recently upgraded to 2.006 (I hope i have the right number of decimal places there) but I had never modded it and I hadn't done anything unofficial with any hack or mod. So I followed the instructions verbatim. When I rebooted, however, I had the system startup message that wouldn't go away. And like so many others, the unit would reboot. This would happen over and over again.
It might be interesting to note that I opened the archives with my Macbook pro. I saw a few posts where this was a concern, and I can add my anecdotal evidence that this may be an issue. I also saw that people have suggested removing everything from MyFlashDisk on the head unit. So, not wanting to have to try everything in "one at a time" fashion, I decided to use Windows to extract the files onto the SD card, and when I copied the files from the dump over the the AVIC-F7010BT, I made sure to delete the MyFlashDisk files first. Luckily, even though I don't have any dedicated Windows machines at home, I have Windows installed in a virtual machine (VMware Fusion).
The conclusion: either extracting and copying the files in Windows, or removing all of the MyFlashDisk files prior to copying (or both of these things) fixed my problem. Now the unit starts up normally and it does not reset after a few minutes.
Please let me know if you have any other questions about my experience with the upgrade. I think I have given you all of the relevant information, but maybe I have missed something that you might be interested in. Anyway, I hope this helps someone else.
Posted Oct 27, 2009 · 17:45 UTC#2
Hi Steve,
did you open zip files and rezipped them on a Mac? Did you just use the tool that comes with the OS? Did everything work after that? Reading many posts, I got little reluctant trying that. Would be great if it worked since then I don't depend on others. I dream of an on-screen TMC status a'la iGo / Clarion - in Germany navigation is futal without TMC.
Thanks for your post
Posted Oct 27, 2009 · 17:48 UTC#3
I'm just talking about taking the x910bt.zip file and decompressing it for transfer to an SD card. The combination of unzipping it in Windows and using Windows to transfer it to my SD card worked like a charm. I didn't unzip and rezip any of the files in that dump.
Posted Oct 27, 2009 · 18:14 UTC#4
thanks for your reply, just wanted to make sure. Will by a netbook... My Macs are too old to emulate Windows, I still have the RISK-CPUs
