F700 - running iPod in + aux audio (sirius) question
By aleks192 · Oct 29, 2009in General💬 11 posts👁️ 986 views
Posted Oct 29, 2009 · 06:04 UTC#1
After I toasted my D3, I picked up an F700 cheap. This has led me to an interesting problem though, with my D3 I used the iPod cable to control my iPod, and my A/V input for my Sirius radio RCA's. Now with the F700 I'm stoked with the increase in functionality with the iPod (I wanted video control the whole time, and got let down by the D3), buttttt that creates an interesting predicament in that the A/V inputs are now occupied by the iPod! So I'm looking to see if there is a solution to allow my to direct in my Sirius without 1. buying the integrated unit, and 2. purchasing the RB-20 style IPbus type device......Any tips??
Posted Oct 29, 2009 · 06:34 UTC#2
You can use the AV2 input on the front of the unit. You will need to acquire a 1/8 inch male AV to female AV RCA type cable to utilize that input however. Below is the Pioneer example of the cable.
http://www.pioneerelectronics.com/PUSA/ ... ts/CD-RM10
Posted Oct 29, 2009 · 14:47 UTC#3
also if you didn't want to use the front input, then you could use a video or audio switch box to hook more things up the AV1. and i dont know if they make one that will work with pioneer headunits, but sirius has a sirius adapter for direct control (from the head unit) of a plug & play unit (they insert into a dock connector for the newer style sirius docks)
Posted Oct 30, 2009 · 00:43 UTC#4
Yah avoiding visible cables is my goal...but thank for the suggestion :)
Posted Oct 30, 2009 · 03:33 UTC#5
Get the Pioneer Sirius option and connect the ipod to the proper input and problem solved.
Posted Oct 31, 2009 · 00:56 UTC#6
iPod is currently on the proper input, and I'm trying to avoid buying another Sirius unit when I have and am happy with mine. A single A/V input on a unit is bad enough, let alone to have it occupied by something it didn't need to before....
Posted Nov 02, 2009 · 14:41 UTC#7
thats why there's two instead of one
Posted Nov 02, 2009 · 19:27 UTC#8
I don't really count plugging a unit in on the front of my deck temporarily an "A/V input" in the sense I'm talking of them.
Posted Nov 02, 2009 · 19:33 UTC#9
Ok those are your choices. If you want to be able to do what you asked you can either spend the money for the sirius option, use the AV2 input on the front, or do nothing at all and remain where your at now. You decide.
Posted Nov 06, 2009 · 18:04 UTC#10
the part you want is the SCVDOC1 $60
you will still need the pioneer sirius translator $60
this will allow you to use the AVIC's touch screen to control a portable plug & play sirius tuner, dock the unit, and pioneer controls it,its awesome
Posted Nov 14, 2009 · 03:52 UTC#11
cool i'll check it out thanks!
