i installed a firmware update to my avic f900bt and the white screen with the red progress line went up to 88% then just stayed there...fifteen min. passed i finally turned the key off. Now when i turn the ignition key back on. The system loads...I wanna say doesn't load completely; because i get a: "fatal application error" window. Then three min. or so the unit shut off then restarted only to keep doing the same cycle over and over ect. Is there anything i can redo or another type of firmware i can install to fix my pioneer. any help would be most appreciated. thank you
Posted Oct 29, 2009 · 11:29 UTC#1
