I Purchased the update 2.6 (factory update) sd cards, and after the update was finished the radio just started to boot normally i got the new pioneer 2009 screen and then it booted into the main menu (destination,phone,av) and in the bottom it says:"system startup in progress please wait , after a few min like 3 min it just boots and does the same thing over and over again ? anyone with any suggestion or is the radio shot ? ![]()
F90BT UPDATE DISASTER
am trying to save myself from sending this unit back to pioneer anyone with any suggestions? ![]()
Did you have any mods installed? If you did, then that is what the problem is. The pioneer updates dont erase the prior flash, it just overwrites it which means that if you have any prior mods, then they will conflict with the update. You have to reinstall your backup. I had the same problem when installing the 3.0 update. I then installed the hacked update and it worked perfect. Reason being is that the hacked update basically erases your flash drive whereas the factory does not.
look if anyone is able to fix this problem i will gladly pay i have a stressful life and dont seem to have to much time to figure it out on my own ? so if anyone is in the NJ, NY area please let me know here is my e mail [email protected] ![]()
