Traffic Shortcut
By bradford · Nov 02, 2009in Hacks/Mods💬 21 posts👁️ 3,141 views
Posted Nov 02, 2009 · 02:08 UTC#1
Hi,
Im running the latest 3.0 firware on an AUS F900BT unit.
I want to create a traffic shortcut on the nav screen similar to those found in the hybrid/complete mod packs.
Is someone able to give me the code needed just to put this traffic shortcut in rather than tryiny to install the entire mod?
Posted Nov 02, 2009 · 06:29 UTC#2
I have it for you. Tonight i will send it to you.
Greatings
Posted Nov 02, 2009 · 18:27 UTC#3
Hi
can you please post the code here? I want to do this mode too. THank you
Posted Nov 02, 2009 · 20:51 UTC#4
Thanks for that - been trying to find it for ages :)
Posted Nov 02, 2009 · 21:04 UTC#5
Can someone confirm if this will work.
If i place this on the navigatemap.ui and place the referenced image in 800x400
;TMC
Posted Nov 02, 2009 · 23:18 UTC#6
;TMC
it should work, the only thing is you should rename the BMP to whatever button you want to use or just grab the BMP from my mod
Posted Nov 03, 2009 · 01:40 UTC#7
I updated my data.zip and loaded it on the unit.
Unit is now stuck on "System Startup in progress, please wait" - I can use everything except GPS
Did i create the ZIP incorrectly, am i missing files?
Can someone please let me know ASAP
Posted Nov 03, 2009 · 01:42 UTC#8
Can you post the BMP from your mode? there are so many modes here... there are so many modes on this sites, not sure which one is which one...
Posted Nov 03, 2009 · 02:25 UTC#9
you might be missing the BMP
Posted Nov 03, 2009 · 03:53 UTC#10
Fixed - i think i stuffed the ZIP when i created it.
How do i work out the screen co-ords? or is it trial and error?
Posted Nov 03, 2009 · 05:45 UTC#11
play with the x and y coordinates
Posted Nov 03, 2009 · 22:55 UTC#12
Ok so i have worked out the coding however two things.
1) What does #2 at the end point to?
BUTTON btnNMB_TMC_onmap bmp="IDT_onmap_TMC.bmp#2
2) I created this image i want to replace it instead of using the TMC icon from IDT.
here is the picture - besides chaning the name is there anything special that needs to happen to the icon for it to work (Transparent etc etc?)
Excuse the amateur attempt, never done reflections or 3D work
Posted Nov 03, 2009 · 23:07 UTC#13
1) #2 means that the bmps has two sections (active/inactive, pressed/unpressed, etc), so lets say you want to make the image that you used to become grey when pressed, then your BMP should look like two images (refer to the image i used)
2) change the BMP used (in this case IDT_onmap_TMC.bmp#2) with the filename of the BMP you want to use
Posted Nov 03, 2009 · 23:55 UTC#14
Using Cs3 - How do i make a section active/inactive?
Posted Nov 04, 2009 · 00:04 UTC#15
create a new image withe the width of your desired button and the length being twice the length of your desired button, copy your image to the new one and place it on the upper part, now make your original image black and white and then copy it and paste it on the new image and now place it on the bottom part, close your orig image and don't save it, save your newly created image to a filename that you prefer and then put that in your 800_480 folder and change the BMP name on the script to the filename of your new BMP
Posted Nov 04, 2009 · 00:11 UTC#16
Cool
So for arguments sake - if i use the following BMP, and want the green part showing on the map i would have buttonname.bmp#1
Posted Nov 04, 2009 · 00:35 UTC#17
Cool
adding the #2 tells the unit that the BMP has two parts and it will divide it horizontal equally and show the upper part and when pressed will show the lower part,
Posted Nov 04, 2009 · 00:41 UTC#18
you my friend are a champ - i am finally getting the whole thing!!
last question, more a CS3 question.
How do i make the icon transparent and save it as BMP?
Also, on a non modded navigate map - the coord x=8 y=251 should site just above the route info, and just below next turn etc
Posted Nov 04, 2009 · 00:45 UTC#19
regarding the transparency search the topic on how to make car arrow and it discusses there the process of it,
for the coord, you have to play with it
Posted Nov 04, 2009 · 04:47 UTC#20
IDT thanks for all the help
Here is where i got my traffic button placed
This was my first guess of co-ords and it worked suprisingly well i think
Thanks for all your help :)
Posted Nov 04, 2009 · 05:34 UTC#21
no prob
