Best method to hookup a BlackBerry Storm 2?
By JoeAverage · Nov 02, 2009in Problems/Troubleshooting💬 4 posts👁️ 813 views
Posted Nov 02, 2009 · 06:14 UTC#1
Hey guys, I was wondering if you could give me a suggestion for the best way to hook up a BlackBerry Storm 2 to a F90BT.
We got a vehicle with this thing installed just yesterday. I thought the front panel had an aux jack that I could just put a male to male headphone cable into, turns out I was way wrong about that.
I'm kinda hoping that there is a way to play streaming pandora from the BlackBerry to the headunit, OTHER than one of those shitty FM transmitter jobs.
Any help you could provide to a technically impaired, and severely uncoordinated oaf like myself, would be greatly appreciated.
Thanks,
Joe
Posted Nov 02, 2009 · 10:52 UTC#2
All the pictures I found of the F90BT has a input jack on the face of the unit. Are you saying yours does not?
Posted Nov 02, 2009 · 12:27 UTC#3
Joe,
There is an aux jack on the front on the F90 and I just plug the headphone into that with a wire. You have to set AV to the second input on the setup to make it work. Check again.
M
Posted Nov 02, 2009 · 17:17 UTC#4
you hook it up the same way i hook up my storm 1, bluetooth for phone calls, and i use the front input jack and a 1/8" to 1/8" cable to play all of my media and pandora, the front input does work, as stated before just make sure that it is turned on in the settings
