F90BT SDMLC Needed* Will compensate
By cabose · Nov 04, 2009in Problems/Troubleshooting💬 4 posts👁️ 1,726 views
Posted Nov 04, 2009 · 15:21 UTC#1
I was wondering if someone could help me out and make copy of their F90 SDMLC. The way to do this is boot up in testmode and click on the DISKRW and select Read and write a copy of their SDMLC to a SD card. Then upload the file or send it to me via email.
I am willing to pay $25 dollars via pay pal for someone to do this form me, and it all but takes maybe a few mins to do. This will solve my F90 problems, (No splash screen on load, hit menu only to get the top menu with none of the functions working on any of them). The file is needed in order to do a full restore back to 2.0, without it, it does not work.
Posted Nov 04, 2009 · 18:56 UTC#2
Check out this posting it's where I got mine to repair my F90bt no splash screen issue.
But it will change your machine code so if you have the 3.0 update's password your sol according to Pioneer.
http://avic411.com/forum/viewtopic.php?f=33&t=25465
Posted Nov 04, 2009 · 20:27 UTC#3
I did see that posting, but that is for the F700. Do you still have DVD, DivX and MSN direct capabilities afterwards? Becuase i know the F700's do not have those capabilitiesunlike the F90.
In Regards to your comment about the 3.0 update's password, i did try to flash over the 3.0 software but it did not work but i did install the 3.0 WINCE file. Now i can not flash back to the 2.0 WINCE file. It wont install it. I am still able to access test mode, but when i try to upgrade to 2.06, it gets to about 45% then screen turns red and it crashes. Probably bc im trying to downgrade the CE. I wonder if i try to use the 3.0 update and then flash over the 3.0 software if that wil work. But am worried based off what you said about the 3.0, if you could elaborate a little more.
*Update* I was able to insteall 2.0 WINCE and got my system back up and running. Looks like you dont need F90 SDMLC file for it to work, it still runs.
