F910BT setting in "AV setting" not active
By jezikk · Nov 04, 2009in Problems/Troubleshooting💬 4 posts👁️ 1,047 views
Posted Nov 04, 2009 · 19:24 UTC#1
Hi all,
What was done wrong, and what can i do to correct it ? Under AV Setting all options expect first 3 (av input, ctrl antena) are not active. I'm not able to change screen size, Mute type, Rear speakers, Auto PI, FM Step.
Can anybody help me with it ?
BR
Lucas
Posted Nov 05, 2009 · 22:36 UTC#2
Check your parking break wire. If it is not grounded I don't think alot of options show up.
Posted Nov 06, 2009 · 07:35 UTC#3
My parking break wire is grounded. I can watch video, put destination while my car is moving. So here i'm sure that it's ok. Any other ideas ?
Posted Nov 10, 2009 · 14:48 UTC#4
:idea: Press the Menu button Go to "Sources" screen and press the "Off" icon , then AV-Settings, then you can acces the icons in AV-setting. After setting the preferences press the Menu button and select the source. That works on mine ... :)
I have to add: I'm from Denmark and have an AVIC-F9110BT European version.
