help
By kbui92 · Nov 05, 2009in Hacks/Mods💬 11 posts👁️ 1,406 views
Posted Nov 05, 2009 · 04:28 UTC#1
can someone help me with the 3.0 update? on the last step im holding down the reset button and the eject button but it just sends me back to the page with my device. help?
Posted Nov 05, 2009 · 08:42 UTC#2
Are you not supposed to hold in the menu, map, eject and reset buttons?
Posted Nov 05, 2009 · 21:03 UTC#3
The guide says the last step is to hold the restartbuton and the eject button down for 5 secs
Posted Nov 05, 2009 · 23:54 UTC#4
Are you using Pioneers legit firmware or the downloaded hack version?
Posted Nov 06, 2009 · 00:48 UTC#5
Can you explain what you mean by "sends me back to the page with my device"?
On a side note did you eject your SD card after the update and reset?
Posted Nov 06, 2009 · 01:37 UTC#6
I'm using the downloaded version. I haven't taken out the sd card so I guess I'll try that. What I mean is that it keeps goin bak to the screen that looks like a desktop on a comp.
Posted Nov 06, 2009 · 20:17 UTC#7
Anyone?
Posted Nov 06, 2009 · 20:21 UTC#8
as long as the SD card with the testmode is in the SD slot its going to keep going back to the "desktop". After you copy the MyFlashDisk to your AVIC just take the SD card out and then do the reset and you should be fine.
Posted Nov 07, 2009 · 02:11 UTC#9
I took out the sd card and the screen goes black whenever I start the car
Posted Nov 07, 2009 · 03:43 UTC#10
Worst case scenario, just reinstall your backup files and start over
Posted Nov 07, 2009 · 23:11 UTC#11
Thnx for the help
